Barnstormer
Member
Whats everyones experience/opinion on original vs. aftermarket pitot tubes. Accuracy/ heated etc.
Pat
Pat
Been running with the original stock pitot tube for 17 years. Works great!
Recently modified it to use the AOA function of the Dynon. Mod cost me $4.
Don't worry about the accuracy. The laws of physics are working in our favour with pitot tubes, so Van's simple piece of tubing and a more expensive pitot tube will both be equally, perfectly accurate, assuming they are mounted clear of the prop wash, not in the wake of something else, etc. Any errors you have in your airspeed system will certainly be due to leaks in the pitot or static lines, or ASI instrument error, or static system position error.Whats everyones experience/opinion on original vs. aftermarket pitot tubes. Accuracy/ heated etc.
How's that accomplished Mel?
Larry
Mel,
Is that bent 60 degrees down from horizontal? My presumption has always been that the exact angle is not critical as long as one calibrates the system. Is that correct?
thanks,
greg
I just formed another piece of 1/4" tubing to nest behind the original with the forward tip bent down 60 degrees and JB Welded them together. Works great.
So Mel, How did you run the extra line to the pitot tube behind the fuel tank and fasten it along the way? How is the connection to the 1/4" alum tube from the plastic tube?
Thanks, I did not want to add the extra probe that came with my AOA system and I think this will work just fine.....
