In the old plans, pages 31-12 and 31-13 showed routing the (then) STATIC line from the tail to the instrument panel bay through the system blocks and the little wire way you built. The old D-180 needed the static line run there and the pitot was a short section from the engine back also to the D-180. Later in the Skyview conversion, this long STATIC line became the PITOT line to the ADAHRS in the tail, and the revised static line never leaves the tail section - it just goes into the ADAHRS. If you have more recent plans, that section has likely been revised but the path is the same.
Here's what you want. The PITOT line is just a cutoff end in the instrument bay and follows the path to the rear of the fuselage as mentioned. Coil it up back at the aft end of the fuse until you mate the tail. Then it will follow the path up to the ADAHRS and connect there. You want one long unspliced line from the instrument bay to the ADAHRS when you are done.
When you do firewall forward, the line from the pitot tube will penetrate the firewall and have one connection to the end that you left in the instrument panel bay. This is in 42C and 42D for us guys that "waited for Skyview."
This is probably enough info for you to find it in your revised plans. It goes through the system blocks - which were also revised to accommodate the ADSB wiring and antenna coax. So look for those.
It seems from reading your post closely that your newer plans have you route PITOT tubing in the tail, from the ADAHRS bracket area to the forward part of the tailcone, then coil and leave it there and route foreward once you mate the tail to the fuse. I do not think this is the best idea because that will be routing it underneath your installed flight controls and up that wire way aroun the brake pedals. I think it much easier to route it now in the fuse and coil it at the end of the fuse. I did not find it difficult to lay in the fuse with my head in the tailcone and route the line up to the ADAHRS which is the way we had to do it as I describe above. I think that is easier.
