jsharkey
I recieved some of the nylon T and Angle fittings with the kit to connect to the back of the instruments but because of their large size it's impossiblbe to screw one onto the instrument and still leave room to connect a second. In my case the instruments are the ASI and a D100.
Are there other smaller fittings that work better? Also these would help with the relatively small gap between my RV6 Panel and Sub-panel and the fact that I installed the RV7 canopy stiffener which takes up some real estate.
On a similar vein - do you use teflon paste sealant on these fittings. Do you need the extra sealing afforded by it or is it an instrument contamination distaster about to happen?
Jim Sharkey
RV6 - Wiring
Jim Sharkey
RV6 - Wiring
