CharlieHotel
I'm New Here
Hi folks
Just hoping I can get some advice on the Pinpoint GADAHRS. We are currently wiring up the Pinpoint GADAHRS to a couple of Chelton EFIS IDU's purchased in 2006 or 2007 (we know we know but the intention was to complete earlier!) which currently have version 5.0B, valid date 07/06/2007.
We have not been able to get the GADAHRS to talk to the IDU's. We contacted Chelton who state the following:
You have stated that the Integrated Display Units (IDU) in the aircraft currently have version 5.0B operating software. To adequately support the ADAHRS, the software must be 6.0B. Due to the age of the software, chances are that the microprocessor and memory are not sufficient to operate the 6.0B software. This software requires 128MB or 256MB of RAM due to the additional terrain and other options that get loaded when it is operating. It is very possible that the current RAM in the IDUs is 64MB. Unfortunately, the unit must be opened to change the RAM which requires it to be returned to us. Additionally, communications circuits on the Mother board may need to be changed to properly interface to the ADAHRS due to the higher communications speed of the ADAHRS.
The units may be returned to our facility for an upgrade called "G2". This upgrade replaces the microprocessor with the latest version (possibly increasing the speed from 250MHz to 900MHz) for improved operation, replacing the RAM to 256MB, inspecting and updating the keyboard PCB for improved operation, and replacing the Mother board if the communication circuitry is not sufficient for the ADAHRS.
I was surprised by the need to do this and also the lack of forward compatibility for a unit replacing the Crossbow ADAHRS. I have inherited the project so to speak so I don't know if the Pinpoint was a replacement or new purchase with the system.
Some of you might have perhaps been in the same position and we would greatly appreciate any advice or comments.
Many thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
CH
RV-10 Super slow build
Many thanks
CH
