gerrydwhite
I'm New Here
I'm about ready to have my RV9A inspected. Talking with the DAR he mentioned that I should have a handbook on the airplane and the engine. I don't have a handbook on either. Does anyone have one that I can copy?
This brings up a good question I had - I'm building my aircraft in my hangar on a private strip - not a public airport. I'm sure I'm not the first to have done this - how do I go about getting the pitot/static and transponder tested before first flight?Of more interest were the airframe and engine Logbooks, properly endorsed including my pitot/static test results, which are a requirement.
Good Luck!
The transponder certification is a flight requirement, not an aircraft certification requirement.
Not much of a distinction, if flight of the aircraft is the intent.
Guess I'll be looking for someone to travel to me with equipment. I'm well outside the nearest Mode C veil.
I used Ted's POH as a guide line. Take a look here http://3limafoxtrot.com/doc/N103LFPOHfinal.pdf
