Pilot Stick Offset
RV8R999
Interested in the amount of offset bent into the pilot control stick for those who chose to go that route? Did you use the stock stick and bend it or start from scratch? Thanks!
Ken
Control Stick Offset
Although he's out of the business, Todd Rudberg still has the drawing on his site for a 1.5" offset. He used to do the work using the stick supplied by Van's. See:
http://rvwoody.com/Stick.html
Using Van's stick has some advantages since the bushing hole, bottom taper etc. are already set.
Mike
