I've studied Vans OP-28 Carbureted Fuel System, OP-32 IO-360 Fuel System, and OP-27 Oil System drawings but these do not include the routing or any other information for the manifold pressure line. I also have Vans IE VMP Install Kit, however this is mainly for use with Vans analog manifold pressure gauge.
I will be plumbing the Oil System per Vans OP-27 drawing.
I'm looking for pictures of the manifold pressure hose and routing from the engine to the VA-169 Transducer Manifold. Does the hose route along the same path as the Vans VA-132 Oil Pressure Hose?
Also looking for pictures of the fuel pressure hose, but on my airplane there is a twist. I'm using a dual battery setup and so I have a PC-680 on each side of the firewall recess (mirror image of DWG 31A ES PC-680 Install Kit). So the routing of the fuel pressure hose is compromised by the location of the second battery.
Thanks for your help
