Paul 5r4
Here are several pics of the panel wire job so far. The last picture is of my very best friend, helper and girlfriend Helen. Without her encouragement, none of this would have come to pass.
In this first picture you can see I'm going with the Fuse block. I like simple and it just can't get much more simple than that. The "shelf" in the forward area is just left over aluminum with a couple small angles riveted in for strength. I did the same type of thing just under the panel just forward of the switchs to support the wires. I wanted a nice neat look and I believe this is achieving that.
The second picture is from the front looking down. You can see the little black zip ties I've used to secure the wires. At first I had run the zip tie through a hole over the wires then back through a second hole. I didn't like the way that looked so I started over and ran the tie down through the hole then around the wire then back through the same hole... result was exactly what I wanted.
[/IMG]
In this picture you can see clearly the way it looks from looking up under the panel. To protect the wires note I've also lined the edges of everything with plastic tubing.
[/IMG]
Another shot more center.
[/IMG]
And the right side.
[/IMG]
And last but really first.... Let me introduce Helen.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
[/IMG]
This wiring and Panel stuff is the part I've most often dreamed about. Maybe we all "couldn't wait" to get to that point. It's nice to finally arrived. Still have one more big "I can't hardly wait" time... Yep... when she's all done and full throttle has been applied to that first flight. Back to work!
![adkvm1.jpg](/proxy.php?image=http%3A%2F%2Fi25.tinypic.com%2Fadkvm1.jpg&hash=e167f63d5af2b7976f3ca4ae6b52b620)
![33xbfpv.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi29.tinypic.com%2F33xbfpv.jpg&hash=096cc723f49d2288d1cfdf45eee750ae)
![29oqzia.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi28.tinypic.com%2F29oqzia.jpg&hash=9e5302f4204150807f79e6361d3b0c4b)
![160ac7d.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi31.tinypic.com%2F160ac7d.jpg&hash=ad6b15eec4efb33a889ab08fffcde7c7)
And the right side.
![19wg3q.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi32.tinypic.com%2F19wg3q.jpg&hash=6190b243ca7486505c61450afdeaa8fc)
![vzd10k.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi25.tinypic.com%2Fvzd10k.jpg&hash=782d6b325e3869f4bebf6fc0b88cbbee)
