What issues might be considered for someone that wants to take high quality photographs from the cockpit of an RV?
Are some models better than others?
Side-by-side RV's make it harder for the pilot to take pictures out the right side. Some times it's hard to turn around and come back the other way.
The RV-12 supposedly has better all around visibilty. Is the field of view of the ground that much better than a 7 or 9?
Reflections off the canopy can be a problem. Does the color of panel and interior make that much difference? How about the roof of the RV-10; does it help reduce canopy reflections? Maybe this issue isn't important if one uses a polarizer filter, and sets it to remove the interior reflections.
What good or bad experiences have you had as you've tried to take pictures from your plane?
