After over 30 hours of flight, I have been puzzled by the somewhat invariable rate of fuel consumption for less-than-ideal performance. I have to admit that I have a little different version of the -10 than most:
Checking in with the Hartzell folks they calculated a 6% efficiency drop in my propeller compared to the blended airfoil that Vans sells, could cause it to fly about 5 knots slower for the same power output. I have no idea what the fuel rate difference is in carb vs FI for the 540 but would anticipate, likewise, that my version would be less efficient at metering fuel to the engine.
In my flight test 130nm triangle at 8500ft in August, I was seeing top TAS at around 155kts with full throttle and RPM at 2500, leaned appropriately. The test flight revealed a 15.5 gph thirst. Talking with operators of a 182 at a local airport that also has an O-540, they would budget 15 gph for flight planning. That's a far cry from what I was anticipating...
If I seek an economy cruise, after studying the power curve charts from Lycoming for this model of engine, it should be in the range of 2200 and 20 inches, but then my TAS is about 129kts at 13 gph. At a more pleasant sounding 2400 and 21, I am getting around 140kts, but still see 14 gph. I see a disturbing trend here where gph = Vkts/10
My indicated fuel pressure is typically in the neighborhood of 125psi, which I don't believe (so says the EFIS) and that is purely the mechanical pump.
So, what do you all recommend I try in order to improve my performance and fuel consumption (other than replacing the prop and engine)? Certainly, getting the wheel pants on might help a little. Could the carburetor need adjustment or overhaul? Other suggestions?
Doug.
- O-540-B4B5 (235 HP, low compression, carbureted, 2575 top rpm)
- Hartzell 'traditional' matched prop and hub
Doug.
