PERFORMANCE AND ENGINE PARAMETERS
henriquerv9
Active Member
Hi all,
My Rv7 is finally flying and now it has accumulated 12 hours on hobbs.
I would like to compare my numbers with others RV's, as i dont know much about engine parameters. Any suggestion will be appreciate.
Here's my config : sensenich metal propo 72x85, TMX IO360 180HP ENGINE, ALL FAIRINGS ON LESS THE INFERIOR (wheel) INTERSECTIONS FAIRINGS
PERFORMANCE NUMBERS @ 8500FT AND 75oF:
169 KTAS @ 2450RPM AND 19/20MP
ENGINE PARAMETERS MOST OF FLIGHT
highest CHT : 400F
highest EGT : 1390F
Oil temp : 180F
Oil pressure : 71 PSI
fuel flow : 28 liters / hour (aprox 7.4GPH)
how is my performance numbers and engine going comparing to you guys?
Regards
Henrique Castro
RV7 PPXVH
Sounds spot on
Sounds like you have a great airplane. Temps and fuel burn sound good. You will pick up another knot or two with the intersection fairings on. Good job!
