M6 - OK. So now how long of a bolt for proper tighting without bottoming out?
Didn't they come with the 680? I thought mine did.
Mine was down in the shop, I measured it and it is 1/2 inch maybe a smidgen less, probably a metric equivalent to 1/2 inch. This holds the lug just fine.
Those that came with my batter appear to be stainless steel , if that matters.
Yes, and you will need a 10mm wrench at your hangar. That is the only metric tool in my hangar.
