I found some info but not exactly what I was looking for (probably didn't find the right thread) so please excuse if this is a repeat.
I am writing my POH and would like some base numbers to start with regarding numbers in the pattern. When I flew a Bonanza, not only was speed important but engine settings to get there was a big part of it.
So here it is. The plane is a 7A with a IO-360 (180hp) and a CS prop.
I'm looking for speed, manifold pressure, and rpm - at the different points. Also when and how much flap is dropped for each leg of the pattern. Also any tricks such as a little nose up when you drop 10 degrees in a C172 to put on the brakes and start down when abeam of the numbers.
Entering the pattern
Downwind
Base
Final
Downwind
Base
Final
