Anyone know the part number for the block that the canopy pin slides into on a RV-6A. The plans I see online show a tip up canopy and I can't seem to find the sliding canopy plans on there.
On my -7 the delrin block itself is p/n C-665 and the bracket it sits in is C-677. I'm guessing it's the same part since those look like RV6 part numbers.
The block is cut from 3/4" UHMW PE plastic, so you can easily " roll your own" if you have access to a drop or table saw, just in case there is any difficulty in obtaining it from Vans.
