Mike S
Senior Curmudgeon
I installed a Matco parking brake unit in my 10, utilizing a left over bracket that came with the airplane. I believe the bracket was for the Fawcet style fuel pump, used if you have a carb, not used for the high pressure pump in a F.I. system.
Anyway, I mounted the parking brake unit to the bracket with a couple of nut plates, (just in case I ever need to remove it, life will be much simpler), and cut the bracket down in length to just over half-----size dictated by the brake module.
I drilled out the rivets holding the stock bracket on the firewall, where the flex hoses mate up to the hard lines.
The removed bracket was used as a drill jig to locate the holes on the unit replacing it-----not quite the correct size, but close enough.
With the parking brake bracket/module riveted back in, the lines fit perfectly----no having to re-do the lines.
![](/proxy.php?image=http%3A%2F%2Faycu14.webshots.com%2Fimage%2F29493%2F2002600438697041717_rs.jpg&hash=4e76f0d4d81bf32b1c7e4d5c01a27a97)
