Has anyone added a parking brake to their 12 and have photos
joedallas Well Known Member Jun 5, 2013 #1 Has anyone added a parking brake to their 12 and have photos
R rgmwa Well Known Member Jun 5, 2013 #2 Some information here, Joe. Posts 52 and 106. http://www.vansairforce.com/community/showthread.php?t=55537&highlight=parking+brake&page=6
DonFromTX Well Known Member Jun 5, 2013 #3 I did mine exactly like Rudi, very easy addition, and to me very necessary..
Y yankee-flyer Well Known Member Jun 5, 2013 #4 Van's tow bar. Van's collapsible RV-12 tow bar also serves as a parking brake, rudder lock, and aileron lock. Use your seat belt and you also have an elevator lock. Wayne 120241/143WM
R RFSchaller Well Known Member Jun 6, 2013 #5 Maybe it's just the way I drilled the holes for the detent balls, but mine won't reliably lock the brakes.
Gagarin737 Well Known Member Jun 6, 2013 #6 You have a second change when you drill a hole on the other side of the "pipes with the hook". I initially had no pressure on the pedals, I gave the other hole a 1/2" extra.
joedallas Well Known Member Jun 6, 2013 #7 Thanks All Thanks All Don do you have photos and how did you hook up the lever and what is the model number.
DonFromTX Well Known Member Jun 6, 2013 #8 I just used a standard cable from Aircraft Spruce, the brake unit is a Matco brand, see it here: http://www.aircraftspruce.com/catalog/lgpages/matcoPBVALVE.php?clickkey=8314. [/IMG] [/IMG] Last edited: Jun 6, 2013
