WingedFrog
What the PAP says:
- With the flap handle in the retracted position hold the left flaperon trailing edge aligned with the wing tip trailing edge
- Verify that when 10 to 15 lb upward load is applied to the trailing edge of the right flaperon, there is no more than 1/2 inch upward movement at the trailing edge
What I found: 3/4 inch movement
I have no clue on what to do...
