We are building a three piece panel to allow us easier access for maintenance. The only way that can work is if you can take the panel piece out with enough slack.
So? Easy solution. We built four temporary braces to hold the panel away from the frame while wiring.
Notice the center stack does not have to be out. You have side access to that.
We still need to clean up the wires and have good anchors for them. The loops will be the right size though.
It may be easier, but still not easy. Lots of wires to go.
CC
CC
