Question to Vans 9th Feb
I know you guys are busy, but is it possible to post a drawing of the panel, with any no-go areas (stiffeners etc.) so folk can dream while waiting? Any news yet on whether you will recommend/require Dynon and/or AFS?
Response back 11th Feb
We don't have final drawings yet for the 12. I would expect that when the kits are available, a panel drawing will be available for download, as for the other RVs, which should be within a couple of months.
The avionics package will contain the Dynon D180. If it is built as an E-LSA, that would be required. If it is built as an EAB (more likely in the UK), you can probably use any instruments. At present, we do not envisage compelling builders to buy the D180 as part of the airframe kits.
