Aiki_Aviator
Hi guys,
I need to get an AH for the 10 and it seems like it needs to be set to a particular tilt angle.
I have based off the door sill as 0 degrees and panel angle is between 6-7 degrees off the vertical.
Does this sound correct?
And if so do I need to get exactly 6 or 7 degrees for accuracy, or will 8 degree tilt angle work ok.
NOTE: this is for a new RC Allen digital AH.
I am also wanting to know what the AS range should be. I am looking at a TSO'd ASI from UMA.
Which of the following would best suit?
T16-211-240 40-240 Knots 10-03593
T16-211-260 40-260 Knots 10-03595
T16-211-300 40-300 Knots 10-03597
Thanks everyone in advance.
