So we've gathered most of the pieces to execute our panel revision over the past 9 months or so. Now we're ready to put them to good use. The one thing I'm not sure about is the EXPBUS solid state breaker system that we have. Any one out there using it in an IFR panel? If so, please share your thoughts or experience. Just want to make sure it'd be an appropriate component in the end, or that the cost of replacing is justified. Any input is appreciated from wisdom of the forum.
I entertain the VP-X unit because it'd easily interface with the 8.4in GRT Hx's, and I like a lot of the features it brings to the table (trim speed different at high and low airspeeds, starter protected when engine running, etc, etc). But the price tag holds me back.
We could always switch over the old fashioned circuit breakers... not free either.
Here's the current panel and the rough sketch of the goal result. (Once we get a 430w, it'll replace the EIS4000, which will likely get remote mounted at that point; the audio panel will go to the top of the stack).
The initial panel was via Affordable Panels, but we might be going with someone local and change to a traditional one piece panel. Also open to any lessons learned with that switch.
Panel main components:
Dual AHRS 8.4 GRT Hx's, TruTrak VSVG AP, PMA8000b, SL40, GTX330, EXP BUS indicator module and switches (or VP-X, or push-pull breakers).
Ryan
![2a5nlg3.jpg](/proxy.php?image=http%3A%2F%2Fi37.tinypic.com%2F2a5nlg3.jpg&hash=d18fc1dd845158217471105a4fc38745)
![2j3qpvk.jpg](/proxy.php?image=http%3A%2F%2Fi35.tinypic.com%2F2j3qpvk.jpg&hash=9fda9281692a89c876d94827b33160be)
Ryan
