thompsonbr87
Looking for opinions on my panel layout. What does/doesn't work physically? Ergonomically? Anything in particular to watch out for? 6A-Slider
Shout out to eHangar.org for their panel design tool.
Across the bottom, switches are:
(3) Battery, Alternator, Emag
(4) Lights - Panel, Nav, Landing, Strobes. Any suggestion on the order of these?
(1) Pitot heat
(2) Avionics, Turn Coordinator (S-Tec 30 - Does it need a dedicated switch? Just copying what already in the plane for now)
The two switches above the S-Tec 30 are Autopilot, and the 2nd is actually a button for Alt Hold (eHangar doesn't have momentary push button).
The vertical switches above the throttle are fuel pump on top, flaps on bottom.
Push/pull knobs between mixture and circuit breakers are both cabin heat. (One on each side. Should I ditch that set-up and just have one control?)
(1) Pitot heat
