Brantel
Please share your thoughts on the following three layouts and let me know which one you like best. The last one is based around the possibility for a 696 in the plan.
Most of the equipment other than the GPS choice is pretty much set in stone. This panel will be 1.5" taller than standard.
Option One, side by side Dynons and 496
Option Two, stacked Dynons and 496
Option Three, stacked Dynons and 696
With this panel I would have:
2 Full Efis's, battery backup
1 EMS, battery backup
1 Dual Axis AP
1 EHSI
1 NAV/COM that is almost the same as two with the standby monitoring and the dual VOR capability with the Dynon EHSI
1 VFR GPS/Map/Weather and Traffic if I add a Zaon, battery backup
Backup ALT, AI with battery backup & ASI
Backup NAV/COM handheld with connection to external antenna
The mission is day/night VFR with the ability to stay IFR current and pop thru a layer or two every now and then.
![1-1.gif](/proxy.php?image=http%3A%2F%2Fi279.photobucket.com%2Falbums%2Fkk133%2Fbrantel%2Fpanel%2F1-1.gif&hash=e767644102644024813d101e96d9d812)
![2.gif](/proxy.php?image=http%3A%2F%2Fi279.photobucket.com%2Falbums%2Fkk133%2Fbrantel%2Fpanel%2F2.gif&hash=976021d9d1186b8c979de5f6b0553208)
![4.gif](/proxy.php?image=http%3A%2F%2Fi279.photobucket.com%2Falbums%2Fkk133%2Fbrantel%2Fpanel%2F4.gif&hash=802bd55b295121122e8ac51d21e8d48a)
1 Dual Axis AP
1 EHSI
