Greg Arehart
I finished the bottom wing skins today and have gotten to the point of putting together a tentative panel design and would like input from the group on 1) functionality/ergonomics; and 2) any missing items. The mission is day/night VFR, at least initially. My wife is also a pilot and wants controls accessible from the second seat. Our goal is simplicity and cost-effectiveness, along with the aforementioned functionality. Panel is the standard sized Vans panel with no extensions. I'm not sure whether I have exactly the right number of circuit breakers, but it should be easy to add more in the final design (comments on whether to put all avionics on separate breakers?). Ultimately if we go to "light" IFR, we would probably replace the 496 with a Garmin 430 or whatever is equivalent. TruTrak is also down the road for budgetary reasons and will be a 2-axis (I have already installed necessary brackets). At present I plan to go with toggle switches and pullable circuit breakers. I have built a custom console for a quadrant throttle, which will also house the manual elevator trim and fuel selector. Quadrant is far enough from the panel that it should not interfere with switches accidentally. Two small steam gauges as "backup" and because I need something that is round on the panel! Final positioning is subject to slight adjustments as I encounter immovable obstacles (have already moved panel support ribs outboard). I am thinking of installing better vents than the standard Vans issue, in holes in the panel as shown. Powerplant is a Superior IO-360. RV-9A tipup.
I will appreciate any input on what is good, bad, and ugly. Thanks in advance.
greg
![arehartpanel108cm6.jpg](/proxy.php?image=http%3A%2F%2Fimg512.imageshack.us%2Fimg512%2F7818%2Farehartpanel108cm6.jpg&hash=bf16179051033d45109cbf7ead8f0eed)
greg
