Hey everybody ,
these days I?m quite confused concerning my panel plannings.
As I?m building the RV9a with the tip-up canopy, I don?t have as much space in the canopy as with sliding option because on the left and right side of the panel there are two holes each side, which supply the frame behind it.
The problem is, that I have bought the Dynon Efis 120 and the Motorscreen both 7inch wide. It?ll be wonderfull if they fit straight in front of the pilot?s/copilot?s view, but -DOH- the two mentioned holes are in between...
Any solutions (except for fitting the avionics to the side)?
And by the way, actually my main question:
How did you plan the panel? Including all Plugs, Avionics and Instruments?`
I have a general idea how it should like in the end, but yet I do not exactly know how to realise it...
Thanks in advance!
Vini
Thanks in advance!
Vini
