gmcjetpilot
Just curious about folks that have used both standard panel and
added on a lower extension across the bottom of the panel, making a
deeper panel.
I would be interested on how much additional depth you added, any leg
clearance issues, any do over wishes, any changes.
At min I'll likely add a lower extension for the throttle, prop and mixture,
center of panel. I'm on the fence about adding a strip across the entire
bottom. I don't necessarily need the room, but I would use the extension
it for switches and circuit breakers.
Comments, suggestions, tips, tricks?
Thanks George
deeper panel.
Thanks George
