Nice choice of stuffs there.
Might consider moving the G5 to the right for easier right-seat flying and then you can move the center stuff up.
Disagree, assuming you're building for ifr. To be useful as a backup you need that G5 within your normal scan. Keep it close.
Which brings up the question: if your two AI's disagree, which will you believe?
Do I see 2 Flaps switches? One at position 8 from the left and one on the far right?
It's time to cut the panel! Any comments on this layout before it becomes a lot more difficult to change?
Radio stack:
Garmin G5
PMA 5000EX
GTN 625
SL-30
Switches/CBs from L to R:
Headset jacks (not shown), Master, Alt1 (CB), Alt2 (CB), [gap], Ebus feed, Alt. Static, AP (CB), Trim (CB), Flaps (CB), [gap], Pitot Heat, Nav/Strobes, Landing Light, [gap], Fuel Pump, [gap], Flaps
Thanks!
David
Brian, that's a nice looking panel! Much like mine except that you found a way to incorporate those large switches without it looking goofy!
