Hi all,
I am starting to work with UpNorth on a panel design and would love to get some input before I commit to anything. Here is what I am working with:
GRT Sport SX 8.4"
Dynon D10 backup EFIS
GRT EIS 4000
Garmin GTX327
Garmin GTR200
Ipad RAM mount on passenger side panel
My wiring will be essentially based off of the Vans wiring kit. I do have a backup battery in the D10.
In the plan, you can see I also have a GNS430 or similar spec'd. I do not plan on adding that immediately, but rather down the line as funds allow. For that reason I'd like to leave a spot in the panel and just cover it with a blank until I win the lottery. I know I would also need an audio panel should I go with a 430; I may look for a GPS-only unit.
If you have any suggestions I'd love to hear from you. If you have a slider 7/9 and 8.4" GRT I'd be interested to know it's vertical position on the panel and how much if any of the left forward support rib you needed to remove, as well.
Chris
GRT Sport SX 8.4"
GRT EIS 4000
Garmin GTX327
Garmin GTR200
Chris
