I have selected the colour scheme for my -12 (thanks Joeri), and lined up a paintshop. I will be doing a lot of the prep myself, including the fibreglass items. I think I have some good advice on the prep process, but I don?t know what is normally not painted. So I need some help with this.
Do you paint the inside of the f/g engine cowl? Obviously you don?t paint the silver foil parts.
If you only paint a strip around the inside edges, how wide is the strip? And do you paint the hinges?
I want to paint the inside of the cooling air duct as far as can be seen. What is the best way to do that, and do you use the same colour as the outside?
The tail fairing ? do you paint that both inside and out?
Around the firewall - do you paint the hinges?
I would appreciate hearing what others have done, and any other tips about what not to paint
Regards, Rod
Regards, Rod
