I've searched this forum for previous messages pertaining to the Radiator Hose Assemblies on Page 49-02, and have found some good information. But as usual) I still have a question.
The two hose sections are cut to 30" and 20" in length. Each spring is approximately 24" long (guessing) which means one spring must be cut short to fit inside the 20" hose. I understand that. My question is on the 30" hose and spring assembly. The spring is considerably shorter than the 30" hose. Should I shove the short cut-off spring section from the other hose assembly into the 30" hose to have full internal support for the entire length of the hose, or just leave that section of hose unsupported?
