Hal,
If you just turned it on today, I wonder what version your D180 is at? I think I would run the support software first and see if it finds the D180 and update it to the latest Version 5.4. Follow the instructions for the upgrade exactly, it can be a bit confusing. You will need to get the locked settings file from Van's website, because the upgrade procedure will ask for it. Then you may need to do the switch light work around like John says.
My trim would not run until I adjusted the trim pot. The pot has to be turned counter-clockwise to speed up the trim, which is opposite of what common sense would have you do. You will have to be turned on your head to get to the pot and adjust it. I had to take out the switch panel screws and lift the switch panel slightly then use an inspection mirror to see the pot screw and get a little screwdriver on it. Best to do this with the battery disconnected so you don't short anything out. You can check the trim motor back at the tail with a 9 volt battery to see if the motor runs OK.
The tone in the headset sounds like an alarm, the D180 will start alarming low oil pressure, low EGT, etc. after it has been on for a few minutes. If alarms are showing on the screen, you can silence them with the button on the left, or just acknowledge them with the button on the right. You would also get a tone if the stall warning switch is making contact.
I can come down and give you a hand if you need me.
Tony
