The final step in attaching the fiberglass fairings to the wingtip involves smearing a bead of Pro-Seal around the lower flange of the extension and clecoing it in place. No mention is made of sealing the vertical interface between the hardened flox/epoxy and the wingtip. Surly this interface has to be sealed against water intrusion. It also occurs to me that any water which seeps into the fairing is trapped there. Should there be a weep hole?
Also, is there any reason the a 5-position molex connector housing is used when there are but four wires?
Jerre
Jerre
