On the rite side, we ran org/brn, and on the left side we have brn/blue. We also have the white on the rite side. The white is B167, but on the print on figure 1, it shows two wire on the left. What's the other wire?
George and Meade
#16
The 2 wires on the left hook up to the reed switch. On the right, only the white wire hooks up to the reed switch, the other wire from the switch hooks to ground at the bolt that holds it on to the armrest. The other wires on the right are fuel sender and ELT wire.
It is a white wire that is used to wire the reed switches in series. It is the 42 inch piece and runs from side to side. You might have it confused with the F55 white wire for the GPS data.
