DonFromTX
A check of the archives and other logs indicates I am the only one with a question here. The plans say to put the instrument cover on a table edge and bend it downward. Unlike Vans normal instructions, no exact 5.68 degrees or any guide, somewhere from 1 to 90 degrees I guess, somewhere from the edge back to the screws I suppose. On top of that the diagram shows an irregular bend pattern as well, nobody has a table shaped like that!
The only way you can see if it is correct or not is to screw it on and put some of the panel fronts on, a gazillion screws to put in and take out! By just holding it up there, it don't even look like it needs a bend. Why not use the edge breaker like on all other similar matches? Words of Wisdom from someone who has it done would be appreciated.
