On page 10-09, the instructions say to install the 1/8th inch clear tubing over the shop head on the static port rivet, then seal with RTV (paraphrasing here). Should RTV be coated on the rivet head before slipping on the 1/8th in tube?
Also, the instructions say to heat the tubing before slipping it onto the plastic tee. The tubing will slip on without heat fairly easily. What is the purpose of heating the tubing? Does it cause the tubing to shrink? In that case, should the tubing be heated after being slipped onto the fitting?
Sorry for the number of questions contained in this one post. I couldn't find this topic addressed using the search tool.
Jerre
Jerre
