tim walter
I have completed the tailcone and was about to start wiring the trim motor when I noticed that the WH-P30 trim wires have brass pins on one end.
I expect that end should be at the bow not the stern, but no mention was given about the orientation in the plans (step 5 on page 10-08)
I really don't want to have to crawl inside and rerun the wires.
What I need to know is; later in the construction what happens to the other end of the trim wires? do those pins get cut off anyway? can I re-crimp new pins? or should I pull the wire and insert it the other way around.
Also, if this was critical, why was it not mentioned in the plans?
Did I miss something?
