DonFromTX
Well, I really did it this time. doing the final stuff on the stabilator, screwing on the brackets. All was going well, brought all bolts up to final tightening status - except for one! That bugger acted just like all the rest, no unusual resistance or action, except it would not stop tightening. I am assuming I got either a bad nutplate or a bad bolt, not sure which. Tried to remove it, no luck there either, just turns without backing out.
At this point I am assuming and hoping that the nutplate is not damaged, just the bolt threads stripped, I think some lube would be in order when initially installing these bolts. I assume I can perhaps remove the bolt without damaging the nutplate. Has anyone else had this problem and has a solution? I really don't want to make another stabilator!
[/IMG]
