I've been having a temp related problem with a P-Mag on/off for some time. After shutdown, and setting out in the hot sun for a while, the P-Mag would not properly restart - i.e., the left mag (P-Mag) would not run the engine during the MAG check at runup. Letting it cool, or taking of on one MAG and getting cool air on it, allowed it to run normally. I've sent the unit back to E-MAG for overhaul.
In the process of taking off the P-MAG, I noted that the gear was badley worn.
Has anyone else seen this type of wear? The gear doesn't look like the gear I have on a certified MAG (slightly different forging). I have noted very small ferrous particles in the oil filter, but nothing I would have worried about.... There was no obvious wear on the mating gear in the accessory case....
![PICT1574.jpg](/proxy.php?image=http%3A%2F%2Fi1197.photobucket.com%2Falbums%2Faa433%2Fwstucklen1%2FPICT1574.jpg&hash=8d825912758d2491063e3af9df9e450a)
