The other day I was working on drilling out my elevator horns on page 11-3 of the plans. The plans call for a 3/16" dia. hole that will eventually be for the AN3 bolt. Long story short, I ended up accidentally with a #10(.193) bit instead of #12(.1875) bit. I only drilled through one horn before I realized this. So now I have a perfectly round hole that is slightly oversized about .0055". It's enough that I can tell the slop compared to the bolt going through the rod end bearing.
I saw a few others before me had welded their holes shut and redrilled when a problem similar to this had occurred. I went ahead and asked Van's for their advice. The reply I got was to TIG weld it shut, because if I stepped it up to an AN4 hole then I would have problems with having to step up the rod end bearing.
But what about this? I think I can get a rod end bearing for an AN4 bolt that has the same threads as the smaller blueprint bearing, and importantly is the same width between elevator horns. My edge margin would be decreased but I feel that it would be okay still due to the fact that it's a steel part.
On the Aircraft Spruce link below, click on "Specification Chart". I'm comparing the blueprint MD3616M bearing to my proposed MD4616M bearing.
http://www.aircraftspruce.com/catalog/appages/aurorabearings.php
