Just for you...
Having never ordered one before, I recently sent this to Vans:
"Is this an uncut .063 panel blank WITH the lower edge bent? If so, is the 14" dimension from the bend to the top or the total before the bend?"
With this response... "Part Number (F-6103 OVSZ) is an uncut .063 panel blank with the lower edge bent, the dimension of panel is 14?x42?.
With the images above, you can decide for yourself what is the "most" accurate information that you need
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
