Have fun
My experience/recommendation was/is a little different than what I see posted here.
1-I fit the console with the cabin top on 'and' off the airplane and did the 'install' off of the airplane.
2-The overhead console intial fit on my project was extremely poor. I've done my share of fiberglass work and there was no way this came close to fitting 'out of the box'. Too long at one end, too short at the other end, horrible fit in the middle, and even worse along the rain gutters. I ended up cutting the unit in half near the front to get it close enough that I could even continue.
3-It 'appeared' to me that the console may have been designed around a 'raw' cabin top. The console had 4 LARGE 'ripples' at the 4 hinge attach areas. To 'finish' the gutter areas one has to contour the cabin top for a seamless appearance. Specifically, these areas get blended for a smooth/even finish. The console wasn't close to being compatible with my cabin top. I had to cut off about an 8" section of the flange in all 4 of these areas then layup glass to form new flanges. The entire flange 'contact' areas were 'curled' in that there was very little 'mating' surface to the cabin top.
4-I'll respectfully disagree with the 'glueing' comments. I could be off base but I interperet this as simply bonding the unit to the inside of the cabin top?? I like to build things to last and would be very uncomfortable with this approach. The unit is rather large and the flanges (on mine) were far from flush with the contour of the cabn top. I sanded all of the mating surfaces then laid up 2 layers of 9oz fiberglass cloth and made a sandwich between the surfaces all the way around. I then laid a corner bead of flox over the edge of the flange and laid up 2 more layers over the outside of the flange/cabin top joint essentially making the unit one piece with the cabin top. There is a lot of heating and cooling on the cabin top and (for me) simply 'glueing' the unit in place would be insufficient.
5-I'll agree with the other posters with using clecoes to hold the unit in place once fitted.
6-As far as 'showing off' the carbon fiber, you can see from previous comments that mine ended up getting painted.
All said and done I was able to make the unit fit and make it look nice but it took a lot of work and time for me to get it where I wanted it, but like anything else on the airplane, once it's done it's not a big deal.
Hope this helps
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
