bret
So back in the early day of building, before I learned to look at every single detail of the plans carefully, I got ahead of my self and reamed out the landing gear bolt holes for the 5/16 bolt, I know you experienced builders are saying to your self ( No he didn't, not a 5/16 reamer ) yip thought I knew what I was doing until I read on here something about this .311 reamer, What? I go back and find out I messed up. So, this is for the main gear, I did the taper pin on the nose gear but I don't want to go through that proses inside the fuse, I am looking for an oversize bolt part number, I remember reading somewhere about specialty aircraft hardware with a part number ending in a X or Y ? .005" -.007" larger diameter to accommodate a hole that had a 5/16 reamer gone through? Thanks.
