HELP HELP.....After taking my wings down out of their jigs last weekend, I discovered that I put 2 3/16 holes in each outboard rib where the rivets need to go for the aileron hinge brackets on the outside of the outboard rib. (These holes were for the AN3 bolts that held the angle aluminum/outer rib to the jig). Only one rivet hole will over lap a 3/16 hole. A few of the other rivet holes will just be less than minimum edge distance (1/4") from the other 3/16 holes. I am wondering if I could just run some sort of backing plate on the inside of the rib and put the rivets through the aileron bracket, rib then backing plate and sandwich the rib.
![](/proxy.php?image=http%3A%2F%2Fimg529.imageshack.us%2Fimg529%2F5838%2Fhpim0501fo7.th.jpg&hash=71f4198ec5fdf8e5c229c8ec7507c8be)
Thanks in advance,
Larry in Colorado
Slo-Build 7
Thanks in advance,
Larry in Colorado
Slo-Build 7
