rjcthree
Everyone, I searched this topic on the -9 forum and came up with zip. The -7 forum had a hint of it, but nothing I can use . . .
I'm fitting my outboard LE, clecko'd to ribs, to the main spar. Bottom of the wing matches up nicely, holes align like we've been spoiled to expect.
The top does not line up. The LE holes are about half a hole diameter forward of the pre-drilled spar holes. Way too far off.
I've spent about two hours, moving around ribs and whatnot, measuring and inspecting. The cause that I find is that the wing spar web is not flat - it rises to the center (between upper and lower flanges). It's out of flat by 0.030-0.040" at each flange max, tapering to half that as you go outboard.
Anybody else see this? How'd you beat it? I only see two ways to fix this, adjust the LE ribs (difficult without really messing them up) or do a little reforming of the spar web for flatness - my more likely option - using a form top and bottom and big wood clamps(controllable, repeatable).
Thanks, Rick 90432
Thanks, Rick 90432
