I believe I followed the instructions correctly when trimming the 2 outboard wing ribs, however when I went to attach the aileron hinge brackets and match drilled the #30 holes the edge distance seems quite small. When I used the calipers, it showed about 2.5 mm. To me, this seems quite close and I'm not sure I am happy with that little material. I have decided to make a couple of reinforcement type doublers that will be on the inside of the wing rib to provide a bit more strength. Curious in any others have found this while attaching the outboard hinge brakets.
