I thought that I saw an answer to your ? on this forum.
There are no holes on one side , I think that you are to match the pieces together and then drill through one side to the other thereby using one side as a template, and then rivet them together with the bearing in-between. Be careful that the two are aligned before drilling.
I hope that this is correct and this might help.
Dave
