JackinMichigan
I have nearly all the wires run throughout the fuselage. There are many wires sticking out the 3/4 hole going to the wings each side. (wings not on)
I have yet to run 2 pitot tubes for the Garmin GAP 26 pitot plus the necessary electrical wires.
I am out of room. Cannot get even one air line through the 3/4 grommet going to the wings on either side.
Also, the holes internally below the door opening are full also (both sides)
I plan on adding another hole just above the existing hole, probably 1/2 inch.
Plus, I plan on adding holes to the vertical members below the door opening. Again as small as I can make it.
I need your expert opinion. Weakening the structure???
