Baffles first, then oil cooler and exhaust. After that, you work the flexible stuff around all the other things.
Thanks fellas, a great help as always. If I start with the cowl is it just a matter of doing the initial fit or do I need to do all the filling and prep work, really wanted to do all glass work together in one go.
I know I had to change out the fitting on my fuel pump so I'm glad I did that early on.
