AOA system
Install of the AOA will require the ports at the wing tip, install the indicator, and running tubing into the cabin from the wing ports. Under the panel you will have to mount the control box, run a pitot and a static line to the box with the 2 small tubes from the wing, and run a wire to a flap switch. Sounds more complicated than it really is but I don't see any reason it can't be done on a flying plane. I certainly believe the benefits out weigh those of the basic stall warning kit and the work needed to install it.
Eric Kallio
