train in a trainer - the nose wheel is stronger
Welcome to VAF!!
Well, its good you asked for an opinion, because that is all I can offer. Just my opinion. RV?s are not hard to fly. But I think your question was, if you should train in one from the very start.
There are two areas to conceder here that I can think of. 1. Can you find an instructor that will teach you in an RV? Are they qualified for RV?s? Can you get a check ride in one? 2. Will you be able to handle the slightly more responsiveness of an RV during training?
You should be able to find the answer to the first one pretty easy. Whatever you chose, I would suggest sticking with the type for your whole PP training. The second one is a little harder to assess. I don?t know if you surf. But when you learn you use a big stable board. If you don?t you can become easily frustrated, and it will take much longer to learn. Most who go out with a short board end up quitting because they can?t concentrate on all the things necessary to keep the board stable and learn to surf at the same time.
I would suggest taking a few lessons in a traditional training aircraft and then get a ride in a RV and see if you can do the same maneuvers to the same level of accuracy. I am sure after a little practice you can. But the point is, that the extra practice it took, is the extra you would have to learn if you were training in an RV from the start. But, if you do train in an RV, you will be that much better of a pilot.
I trained in spam cans and then transitioned to tail wheel and now fly an RV-6A. I highly suggest flying an RV as soon as you have the fundamentals down.
Just my 2 cents.
